Jacob
What goes around comes around.
Too late - you've gone there!No, it's The Guardian. As I said, not going there.
These things don't go away if you just pretend they aren't happening.
Except that by saying that, you did go there. I'm not interested in arguing the point, as I'm pretty certain neither you, or any of the usual sneerleaders, will shift your position one degree, but it's dishonest to hit and run like that.I'm not going anywhere near the Catastrophic Anthropogenic Climate Emergency debate, as that is a proselytising relegion, not science.
OK - everybody 'does their little bit', and the UK decarbonises by 2050 (or something close to it).
What happens to the climate?
Which is exactly why I see no point in getting bogged down in an irrelevant, and extremely heated debate on an off topic subject. Let's talk about energy, oil and how to replace it, and what the near future holds economically. When the sea level rises substantially, we can talk about that, too but until then, let's all keep on topic. What say you?Except that by saying that, you did go there. I'm not interested in arguing the point, as I'm pretty certain neither you, or any of the usual sneerleaders, will shift your position one degree, but it's dishonest to hit and run like that.
Over population is the solution - it increases the chance of survivors post apocalypse. It's nature's way!Very little in the grand scheme, but the UK (or by that time, a group of bickering insignificant nations) become(s) the leader(s) in alternative technology and sells it to the rest of the world and perhaps then the economy grows and a significant impact to the climate can be made. However... it might well all be offset by an ever increasing population, which I have always maintained is the biggest problem.
What hasn't been looked at is how much oil we have left - oodles of it, obviously, but all of it expensive to extract. The energy required to extract it has a bearing on our economic wellbeing, and currently we average I believe 15 barrels of oil produced for every barrel consumed producing it. This sounds like a healthy margin, but it is right on the cusp of being enough to allow growth of the worldwide economy. It is only going to get worse from here, as old, cheap wells come to the end of their life, affecting the balance.
I think the point he was making is that the Russian s didn't put the reactor inside a further containment building, as we do. Whether this would have been able to contain the explosion I have no idea.The containment was the reactor casing just like most reactors, and works fine until breached at which point you are in trouble. At chernobyl due to a chain of events they got thermal runaway and the cooling water boiled, the 1000 tonne reactor cover just lifted, then an explosion and the core was exposed and burning sending radioactive material into the atmosphere.
but there would be more zombies...........
It was inside a building upto when it went bang, these buildings around reactors are really just to protect from the enviroment and provide a working space for the operators, often no more than steel frames and cladding. The idea is that the reactor should not explode and release any radioactive material, if it does then you are in trouble.I think the point he was making is that the Russian s didn't put the reactor inside a further containment building, as we do. Whether this would have been able to contain the explosion I have no idea.
No the movie is rated for being a realistic dramatisation true to the events.It is hard to imagine a worse outcome then an out of control core exposed to the atmosphere in a large reactor, and basically all they did was dump sand on it. That reactor should not have been operating in the first place, it was a very dangerous design, it had no plan in case of an incident, and it didn't even have a containment building.
I remind you that the movies are entertainment, and panic sells.
The only contaiment provided by the outer building and this also applies to any other nuclear facility is that during normal operations a negative pressure is maintained within to ensure no radioactive release and that the radioactivity is removed via large filter banks. Also a lot more is put into the foundations in order to comply with seismic regs. Take a look at any of our current severn sites and you will see the buildings are not substantial, because it has not been accepted during the design process that a reactor can explode, a reactor breach is something not visualised, does that remind you of other places.
Forget the movie and watch the documentary in which the actual people that were there are telling their story and it will hit home, in fact it is the most frightening horror story ever told and you soon realise just how lucky we are to be alive and only having to deal with a Covid pandemic rather than a nuclear holocaust. If this had happenened in the UK we would all be dead, it is only the Russian culture and those miners who saved the day and we should never forget the sacrifices those guys made. In this documentary is a nurse who talks about a guy who looks like he has no eyes just blackness and he looks like a zombie, he spent six minutes in a high dose location and she tells him all will be ok to comfort him, but she knows he will die like all the others and yes he dies that day.No the movie is rated for being a realistic dramatisation.
Do you really believe that structure would contain a blast that lifted a 1000 tonne steel and concrete lid?
Of course there is debate as to whether a proper containment building would have withstood that explosion, but if it had, there would have been no deaths, and little mess.
Not always, many who work that sector also realise what a fine line we tread.This the problem with the nuclear fear industry, they operate on the mantra that all reactors are the same, and that what happened in Chernobyl could happen at any reactor, and that is not the case.
