user 26792
- Joined
- 3 Jun 2017
- Messages
- 25
- Reaction score
- 0
Hi All
I'm in the market for some Diamond Sharpening Plates and a polishing compound. I've seen a variety of different sizes and types and quite honestly I'm rather confused about what to go for.
At present my budget does not allow for the Eze Lap plates and therefore looking at the cheaper end of the price spectrum aka lower the better. I've seen some by Am Tech for less than £10 each however I don't know what grit the gradations are, having popped into a TK Maxx they have some different Am Tech plates in a set of 3 for £6.00 but the size is quite small and really only suitable for small knives and chisels not plane irons, the gradations were 200 - coarse, 400 - fine and 800 - super fine. Ideally I would like a set of plates 300 - 400 (Coarse) 600 - 800 (Fine) 1200 - 1600 (Super fine) - also correct me if I'm wrong because this is my understanding of the gradations mentioned. At the moment, I'm using an old combination stone which is 30+ years old so obviously it has seen better days but it still gives me a cutting edge albeit not a great one. As such I'm considering a 2 sided diamond plate and I've seen one from Faithfull and one from Axminster both similar in spec slight difference in price. The other issue I have is that I don't really know what the performance and longevity of the plates will be, I will be upgrading to the Eze Lap when budget permits however I also don't fancy paying out for something that will get 10 sharpenings and die. Any advice would be appreciated.
As for the polishing compound I've seen two with ridiculous price difference between them on Amazon and can't quite understand why, can anyone advise what I should look for in a polishing compound or is any old brick good enough. Considering there's a youtube video showing oven cleaners giving quite good results.
