DeWALT DWXAF101 Workshop Air filter 0.3um
Thedog
25 Jun 2018
Cornwall
Hi everyone,
I am interested in buying a wood workshop air filter unit.
There seems to be many types & brands readily available int he UK.
However, it seems the particle size spec of the filter is normally around 0.5 or 1 um.
After lots of reading about how particles are actually captured, it would seem that the magic number is 0.3um.
Once particles get below 0.3um they behave differently due to their low mass so most units that state 0.3um will also capture lower than this.
Anything higher than 0.3 seems easier to capture (likes large marbles falling falling through a small net - whereas <0.3 does not work like this)
I found that the two stage HEPA offering of the DeWALT DWXAF101 has a spec 0f 0.3um.
But I cannot find any reference to it on the Dewalt UK website and certainly can't find any UK suppliers offering a 230 V version (or a 110V either).
So, where can I buy one from?
Or is what other brand offers a 0.3um Spec?
Seems to be available in the US from Amazom.com
https://www.amazon.com/DWXAF101-Filtration-Collectors-Woodworking-Controlled/dp/B0BGBM3QFX/ref=sr_1_2_sspa?crid=1TYOCFRYYAFCM&dib=eyJ2IjoiMSJ9.28sJgIFj6WTMvR9jehUQL1m9jmPwjHu8nGinHCibHVE.qjqPTNtbkt7nA_FF2uoW0HquDptVIAIxDpKt4Ndx-k8&dib_tag=se&keywords=DeWALT+DWXAF101&qid=1740310991&sprefix=dewalt+dwxaf101,aps,132&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Its also has an automatic mode with inbuilt air sensor (Don't know how good it is?)
UK imports taxes & shipping are high from buying Amazon US and its 110V I believe.
I wonder why Dewalt don't have a UK version.
Uhmmm?
For air filters, I think standards compliance is a big deal. Vendors wave labels about with gay abandon but if they say something is compliant with an international standard, they should be able to show a test certificate and are putting their necks on the block rather more.
For hepa filters H13 is the number.
It means 99.95% of those 0.3um are caught.
H14 means 99.995% of those 0.3um particles are caught (so 10x better).
But true HEPA filters are pricey, need a fairly powerful fan to push the air through, and tend to be bulky too like for like.
If you are working with hazardous silica dust, etc maybe necessary, but for DIY woodwork, I do wonder if that's overkill and maybe an F14 filter (older standards terminology, I'm not sure what the current euro equivalent is) would be enough. Those are typically considered good enough for welding fumes and car exhaust fumes, so pretty fine, and definitely cheaper.
I looked at the link to the dewalt above. It says H11. That's probably why they don't import it.
H11 is hundred times poorer than H13 so I doubt it qualifies as a "standards compliant" HEPA filter, certainly under the ISO worldwide standard, the American standards aren't much different so it wouldn't quality there either.
https://en.wikipedia.org/wiki/HEPA
Thanks, Sideways.
But is it true to say the H11 is better than what filters are fitted to the like of the Record, Jet or Axminster filters?
I would like something that can filter down to 0.3um such as the H13 you you suggest, but what units are readily available in the UK?
Interesting subject, I am sure could go really in depth, a subject in itself.
I have a Camvac extractor which is 0.5um but the two output pipes are vented externally.
Problem is I have no widows in my workshop, so need to keep the dust to a minimum. I have a dust sensor, and its really surprising to see what's thrown up into the air, even went just cutting with my table saw or bandsaw. Its fairly concerning to to see how it spikes up so quickly.
I've just been through this loop - the pro (HEPA) air cleaner options I found were Dustcontrol (Aircube series), Husqvarna (A1000/A2000), Pullmann & Holt, and Maxvac. They are a good deal more expensive than the hobby type.
@Jake
Yes. Those professional HEPA filters have a £100 odd proper H13 filter and a high volume / decent pressure centrifugal fan that would cost you or I probably £200 minimum.
There's a little more for a box, some buttons and a prefilter, but basically they would cost about £400 in materials to build. They seem to sell for £700 upwards but you do get 1000m3/hr or more which will change the air every 6-10 minutes.
All in all, a different class of product to the dewalt / record / jet boxes.
Staying cheap, look at Thor filtration, the new name for the filters that used to be microclene.
Not without issues but the ones I've opened up do use a half decent fan inside and don't have the crappy circuit board that often fails on the other designs.
Ok, thanks. Good info and helpful.
Considering how potentially harmful wood dust is, you would think that the likes of the main woodwork brands would produce and reasonably priced HEPA H13 version for hobby type people. I looked at some of the common brands and they offer 5um /1um (Rebrand imports) which would help but to think that its the smaller sized particles that are harder for the body to deal with.
I will have a look at some of the pro brands like Dustcontrol / Maxvac etc. See where that takes me. Or perhaps price up the parts for a self build unit.
I reckon that many just see an air filter, buy it and think they are very well protected (without too much thought), which may not be strictly true really (In my opinion anyway :))
Maybe I will have a look a second hand unit and get a new filter, if any are available.
Thanks.
