Dewalt DW1150 switch
Teejayef
13 Mar 2018
Gloucester
The teleswitch on my DW1150 planer thicknesser has given up the ghost, - the machine is old, age and brittle plastic I think - search for a replacement show that it's out of stock, probably now replaced by a newer model but how do I find something that I can just screw into place and connect up to do the job? Or am I dreaming that this would be possible?? Any ideas?
Looking at the drawing, item 46 is the switch and 47 a cover which looks like just a simple on/off switch which should not be hard to replace.
You threw my there as by dw1150 does not have that type of switch. It has a NVR with a red stop mushroom, mounted facing out horizontally from the motor body. I can see the same arrangement as part 56 on a similar diagram
A photo from the op would help.
Replacing the original with a generic DOL starter shouldn’t be difficult.
Fitz
Yes there are a few variations on these P/T's but the one thing they seem to have in common is that the parts are no longer available, if it has an NVR then there are a lot of generic versions of these around and it will be a case of making one fit but as said a photo would help.
