As in the title
model number DW3501
Can post a photo tomorrow if any interest
Twin wheel model takes a 82 1/2" long blade
you can get all the parts for this model from here
http://www.mtmc.co.uk/product.asp?P_ID=18573
It runs when you press the green button and stops when you press the red one
£175 :wink:
It is fitted with a safety key , if its not on position it will not run :lol:
also has a warning light fitted
Big cast ally wheels :lol:
Cant find the insert on the table , would advise a quick clean up and check over as not used for about 2 years
6" depth of cut
12" from blade to neck / throat
220 - 240 volt
3.2 amps
0.55kw think that is 3/4 Hp on old money
The main body as you can see is one reinforced casting , whit a plastic outer cover
model number DW3501
£175 :wink:
6" depth of cut
220 - 240 volt
3.2 amps
