A
Anonymous
Guest
Hi all,
I am having a big damp problem with one of my sitting room walls i have tried everything to try and sort it out but just as i thought i had solved the problem it jumped up and bit me on the @%*~.
it all started a couple of years ago when after i had decorated a few months later i noticed paint flaking off the wall, the wall seperates my sitting room from my staircase which is above my coal house (which is no longer a coal house) so the wall that i am having problems with is my coal house wall, with me so far? with it being an interior wall as such it is only a single brick wall meaning their is no cavity so all that seperates my coal house from my sitting room is a single brick wall. i thought that the problem was being caused by cold air condensing on the coal house side and seeping through the mortar joints and thus causing damp in the sitting room side because the flaking paint seem to follow the line of the stairs and if you go in the coal house and touch the wall you can feel that the wall is quite warmer because of the sitting room being warm. So what i decided to do was paint the wall in the coal house with bitumen paint put on some viscreen then polistyrene insulation sheets roughly 1 inch thick then lats and then marine ply to form some sort of insulated cavity to trap warm air and prevent the condensation. so about a month ago i painted on the bitumen and secured the sheet of viscreen with some pressure treated lats ready to put the ply on but today when i went to finish the job i noticed that all along the bottom their was a lot of condensation formed on the plastic sheet so i proceeded to lift up the excess plastic and the floor was saturated so i am now thinking that it is coming up from the floor as when i removed the plastic sheet the wall was bone dry. Please help!
