Rorton
Wasn’t sure to be honest Pete. Does the material from the tenon not need to completely fill the mortise. didn’t think gaps top and bottom would be acceptable?
They say "Measure twice, cut once", but it really ought to be "Think twice, cut once"
Replace that last line with "realise you marked it right the first time and shouldn't have changed it". Far more infuriating that way.Think
Measure
Think again
Measure again
Mark it up
Think about whether it looks right
Go for coffee
Come back with fresh eyes and realise you did it wrong
Think again
Measure again
Mark again
Cut
Wait five minutes
Realise you cut it wrong
I have a "pillar drill" made of finest chinesium - one of Lidl ' s more interesting offerings. It is my intention to get better at this, so I think the next 40 mortise project will be hand tools only - the last mortise I cut ought to be better than the first, you would think. Also, I should stop using cheapest wide grain soft pine. The search for the perfect mortise continues...I feel your pain and frustration, and I hope you can feel how cold damp and locked down we all are here back in Blighty! Sorry that doesn’t help really with the mortise and tenons,
Do you have a pillar drill? You could fit a fence to run your wood against and drill most of it out, I certainly wouldn’t attempt to cut mortises with a router – they do tend to have a mind of their own haha. Random thought, how about putting the router cutter in the pillar drill, never tried it so please don’t blame me. Ian
End grain gluing dosn't have any strength, its just the long grain of the sides that give the strength, so the ends don't have to be square or even fit, you have to watch the allignment when assembling but thats about the only drawback.Wasn’t sure to be honest Pete. Does the material from the tenon not need to completely fill the mortise. didn’t think gaps top and bottom would be acceptable?
Thanks , as above, 5mm all round for a shoulder, with 15mm at the top to leave some meat in the top of the leg - would that be OK - and then a 15mm protrusion
Ive moved the legs in from the edge of where the bevel starts 5mm also
Generally you want to be choosing your mortice chisel based on the thickness of the piece being morticed, so in this case the leg. Look at the joint in cross section, and you've got three pieces glued together - the tenon, and the two sides of the mortice surrounding it. You want the thinnest of those three to be as thick as possible.thanks for both replies, had to lookup haunched M&T! so if I had a 1/4 Mortice chisel, that is enough based on the 20mm thickness of the apron, I shouldn't be aiming for double that width?
Not necessarily Tony, The haunch is usually there to cover up a groove that runs through the joint as in when fitting a panel, actually though in this case as the top of the joint is covered by the tabletop it’s possible to use an open-ended Mortice and Tenon in which case the mortice could be cut in all sorts of different ways. IanI am surprised nobody has yet mentioned that this ought to be a haunched M&T.
My only other suggestion is that I'd not be drawn by the advice to drill out some of the waste. Unless it is a pretty big mortice and a brace and bit might be appropriate. Just get a proper mortice chisel, a big mallet and set to it. The correct mortice size is the width of the chisel you have, set the gauge to it and saw the tenon to suit. Remember to start near the middle of the mortice, only approaching the ends with light paring cuts to get a nice clean, accurately placed end without rounding over from levering. I find drilling it out strangely harder to produce a clean result, and knocking a square chisel into a series of round holes gives increased chance of spiltting the top of the leg.
Cheers. I think I’ll get the 2 tables that are similar done (one slightly smaller top than the other due to space) and then think about if we need another one laterNice thought Rorton, but it doesn’t always just follow that way, its proportions and aesthetic’s, most of the time it’s just what looks right.
I'm going to mildly disagree here. The purpose of the haunch is to allow you to put the mortice a bit further from the top of the leg, whilst maintaining glue area and keeping the joint in good alignment. If it were just to fill up the end of a groove (which it can often be usefully used to do) there would be no purpose for the diminished haunch M&T.
Going back to sizing of the mortice, I think the OP is in danger of over-thinking this. If you are cutting a traditional joint by hand, the width is the size of your chisel, the chisel size you pick is somewhere in the range which is strong enough, without making it really hard work. I would suggest anywhere from 1/4 to 1/2" will be fine for something this size in oak. If I had only space for one mortice chisel in my toolbox, I'd pick 5/16" (8mm ish) as the best compromise.
