Cabinetman
In case anybody is interested I did quite a bit of experimentation when I built my sloping headboard and it moves through 25° out from vertical sounds a lot but it isn’t much when you see it. Ian
They offer the beds in either soft wood or Oak, the oak version of the one i am basing my one on is 4500 ish, the softwood version is 1500. So a fair saving.That video show that they are using pretty cheap softwood but making high value items from it
Looks good, how are you doing the K/D fixing so that joints don't show and it doesn't work loose?@Cabinetman and everyone, just about finished the first draft of the design, here are a couple of basic renders from Rhino, based on the revival beds one, not exactly the same, but close.
The only part i'm not sure about are the feet, should i leave the bottom of the boards to come down, or chop them flush and put feet of some sort on it?
Any opinions welcome.View attachment 125865View attachment 125864
Thanks, hope it looks good when finished.Looks good, how are you doing the K/D fixing so that joints don't show and it doesn't work loose?
Cheers James
Just a first drawing. Will put in as many as I need to when at that stage.Needs far more slats, mine has about a dozen
Yes i was thinking to make them slightly higher, just drawing out some foot ideas just now, maybe even buy something ready to go, not sure. And as far as the dowels go, i have access to a large metal lathe, so my plan is to get square blanks and make them on that. and cutting the slot for the headboard and footboard on the table saw. Lots of ideas, hopefully they will all work, fingers crossed anywayThe side rails probably need to be a little higher. You will want to get a hoover under the bed at some stage. ? Those Festool K/D fittings look ideal and you will only need four as they are reinforced with wooden dominoes. Those 7' dowels across the bedends look tricky unless you can find some huge router bits with the correct radius.?
I agree beds usually have 2x K/D bolts in each rail...Those dowels as you call them don’t really need to cause you much anguish at all, if you look back on page one at that sleigh bed I made those top sections which are probably 4 1/2 inches across, aren’t round and they were cut by taking slices off on the table saw them just finishing off with a hand plane, didn’t take long at all.
@recipio I certainly would want to fit more than one KD fitting on each corner, the stresses just from the size and weight of a bed like this requires it ime.
Yes that’s a good idea and it fits the design nicely.Thinking to put two of the domino connectors in each corner, have changed the bed slightly now to have legs that support the ends and the ends of the side rails. Just make feet from 40mm stock and domino them in the underside.View attachment 125972
.Not so sure. All the promo videos for the Xl connector show a 25 mm hole in the post and a 50 mm hole in the rail. They also show one wooden domino above the connector or even a connector in between two dominoes. I don't think a 25 mm depth is strong enough for a bed but I'm open to correction.I agree beds usually have 2x K/D bolts in each rail...
I wasn't thinking of domino connectors just your ordinary furniture boots and barrel nuts....Not so sure. All the promo videos for the Xl connector show a 25 mm hole in the post and a 50 mm hole in the rail. They also show one wooden domino above the connector or even a connector in between two dominoes. I don't think a 25 mm depth is strong enough for a bed but I'm open to correction.
