I've decided that my next project is going to be a Demi lune table, not least because I want to have a go at making something with a curve in it. Mine will be a half ellipse as I want something a bit wider and shallower than a semi-circle would give me.
I'll try to make this into a proper build thread when I get going, but I have a few initial questions which the wise amongst you might be able to help with.
The basic design will have two rear legs at the junction of the curved front apron and the straight rear apron. There will be two front legs "attached" to the front apron (how they're attached is one of my questions). I've decided to go with bent lamination for the apron because I have the tools to do that. The idea is to re-saw thin strips and glue them together in a male/female mould.
I'm thinking ahead to the leg joinery. My questions are:
1. Do I make a one-piece front apron and "slot" that into open mortises cut in from the tops of the legs (I think this method typically involves a rebate on rear of the apron only), or do I have the apron in three pieces with more conventional mortise and tenon joinery? One advantage of the three-piece route is that my lamination moulds will be a lot smaller as they only take in part of the curve (there would be two moulds - one for the centre piece and one for the outer pieces). However, I can see that the joinery might be a bit harder with the three-piece.
2. I'm struggling a bit to envisage how I would lay out the joinery because of the curved surfaces. Even if I go with a one piece front apron, I will still need to mortise and tenon into the rear legs. Are there any good techniques/tricks I can use here? I can see that a full scale drawing might help so that I can measure angles, but the lack of a flat reference face for some parts will be a challenge I think.
As ever, any thoughts and suggestions would be much appreciated.
(I'm not sure it's all that relevant, but I'll be making this in oak - I'm trying to limit the types of timber I'm using at the moment as it keeps things simple. I was looking for a "special" piece of oak at the timber yard on Saturday to use for the top, but couldn't find anything quite right so I might replace the top at a later stage if I find something. I did find one piece which initially looked ideal - packed with medullary rays - but on further inspection it was also packed with worm holes/tracks! Most of these tables tend to have a lot of inlay and marquetry work, but I'm going for a clean look on mine!)
