delta scrol saw
bobman
31 Aug 2009
kent
finally got one, managed to pick up a delta 18" q3 with stand for £42 very nice saw well worth the wait
well done, any chance of a pic of it, and does it have the quick clamp blade change, its so easy with that. :lol:
hi steve its the quick set 2 clamps top and bottom make blade changing so easy id show you a pic but dont know how bob
glad to hear it bob, mine has those clamps too and its so easy to blade change and very quick.
look forward to seeing what you produce.
hi frank worth the wait so simple to use. the excavator i've just started but will be very slow progress has i will be doing it in between other jobs bob
Hi Bob ,
Glad you like your new saw , :D just keep an eye on the little 5 mm nut & bolt that adjusts the blade clamp, if the blade doen't clamp after a while, replace the nut & bolt , more than likely the bolt will be bent !!!!!!!!
and don't forget to lubricate the pivots on the arms , it should last a life time , :D :D
------------frank------------
