Superduner
They are usually so cheap to replace that I change them as a first step and then go further if that doesn't solve the problem.
£25 for the pair, I don't mind the cost if that's the cause. Anyway, I ordered them, thanks for the parts link whoever provided that further backThey are usually so cheap to replace that I change them as a first step and then go further if that doesn't solve the problem.
This is just thinking out loud but it sounds as if you may have a centrifugal switch for the start/run functions on that motor and it isn't switching as it should.
Had a similar problem with a Jet lathe some years back and fixed it with excellent advice from Myfordman here. This video gives an idea of what to look for
