You don't need to anymore, this site has it's own backroom, just need to ask the adults for permission.Funnily enough I am not allowed to join there
Could you be more specific on who "the other Forum" is?
It may well do all of those things, but simply not necessary on a well made machine.
No harm in it if you want to do it of course, but it really is not necessary, or at least hasn't been for me for the last several decades of use
Ditto, though 20 years for me.I've neither snapped a blade nor taken the tension off in ten years.
I have heard it can create flat spots on the upper wheel, but if it has i couldnt tell you with my rattly old bandsaw.
Sounds like the saw blade is the problem, maybe had a crack in it.
Have you examined the rest of the blade to see if there are any other cracks ?
If theres none, email back to tuff ,quote what they've said and reply with WHAT A LOAD OF BOLLAKS.
I have just tried to Register & I received an email; which said =Funnily enough I am not allowed to join there
Unfortunately due to recent overloading with spam accounts we have taken
the decision to only approve accounts manually rather than automatically so
this will mean your account will need manual intervention from a forum
Admin to approve it. This should hopefully take less than 24h as we are
generally online most of the time, but please be patient with us and
understand that this decision wasn't taken lightly and was done for the
benefit of our community to not have to deal with the spammers incessant
posting of nonsense.
Your account is currently inactive and will need to be approved by an
administrator before you can log in. Another email will be sent when this
has occurred.
Your password has been securely stored in our database and cannot be
retrieved. In the event that it is forgotten, you will be able to reset it
using the email address associated with your account.
SO PERSEVERANCE MAY WORK, Rorschach !
Interesting, but I have a cheap, lightweight Rexon machine as well as the bigger, heavier duty Startrite, and neither have been habitually de-tensioned over the last several decades, without any noticable detrimental effects.I certainly don't want to get into any arguments, especially when I don't have that much band saw knowledge paulm, I think a LOT depends on what tool you have. IF a band saw consists of a frame which is "just bent up" out of thin gauge sheet steel (meaning most of the frame strength comes from the bends themselves, which in my cheapo it certainly does, AND in several others I've seen) then as a fairly well-trained engineer myself, I'd "guess" it's a racing certainty that de-tensioning would be a necessity unless said band saw was in regular daily use. Mine certainly is not, hence de-tensioning after every use.
But for the sake of at least trying to sound at least SLIGHTLY civilised TRITON, I'd recommend that you add to your "LOAD OF BOLLACKS" the phrase QUOTE: .... in my 20 years experience. UNQUOTE:
And IF you have an real engineering knowledge you may care to add QUOTE: It's most unusual for bent thin gauge sheet mild steel to crack. It usually just distorts before cracking, often so little that distortions can only be detected with straight edges and measuring tools. UNQUOTE:
The first statement is a guess and not supported by analyse. The break at a point other than the weld more strongly suggests that there was a fault in the blade at that site, that over time and continued flexing gave way, yes running the blade with too much tension can speed the development of the fault in the blade but unless you grossly over tension the tension itself doesn't cause the breakFor the blade to break ,other than at the weld, it would suggest that it was over tensioned. I consider that Ian at Toughsaw is a real expert on saw blades,
The odd breaks that I have had in the last 5 years have been at the weld, never in the blade itself.
Its a real world example AES. For 20 years Ive left the tension on.
Were this a problem, then my blades would be snapping all the time wouldnt they ?
So tell me why they dont.
Please avoid going on about technical understanding of engineering principle and just explain why my tensioned blades dont snap when you are tuff are suggesting that exactly what they should be doing. Because thats is in stark and direct opposition to tuffs reply.
A quote from 'Lumberjocks' on this tensioning subject
" I bought my bandsaw, a used Walker-Turner 14” bandsaw around 1960. In 55 years I have NEVER de-tensioned a bandsaw blade. And . . . . the blades just keep cutting just fine. So much for the de-tensioning in my way of thinking. "
Again, in direct opposition to tuffs explanation.
The way it looks, tuff are trying to get out of replacing a blade that clearly had a flaw of some sort in it.
So clearly and logically someone is wrong.
Tuff say its because they arent releasing the tension, and my and phils real world example flies directly in the face of that, which suggests VERY strongly that tuffs explanation is utterly incorrect.
So if you are willing to accept that AES, can you say what other flaws that would be in a blade for it to snap prematurely.
Cant be many examples for you to select from
I don't doubt your engineering expertise but, on this topic, my own and other folks real life experiences over many years is not imagined
