sploo":xhxy8w5n said:Good suggestions - thanks. Shame I didn't see it until now (having just flattened it this evening) :wink:
As it happens, I've got a glass float plate which is flat enough that it's probably a higher standard than my skill level with a plane (if that makes sense). It wasn't bad at all - just a line about 3/4" wide where it's maybe been used to plane a lot of board edges.
Having done that, I decided to attack my #4. Turns out that had a much more significant twist in the sole, but I've mostly got that out too.
Finally I did ease the edges and toe and filed the heel on both planes. I ran out of time this evening to do a proper clean of the #4 1/2 and wax both, so for the moment I've just wiped the soles down with some 3-in-1 to prevent them rusting.
... I've picked up some bubinga (with the intention of making a new handle and tote). Cross fingers it'll end up looking pretty nice; as well as the important bit of actually being useful.
Thanks. I've found this rather useful link http://www.leevalley.com/us/wood/page.aspx?p=63262 which I'm hoping will help me get the basics right. The shaping I'll obviously base on the existing totes.Cheshirechappie":gue8rwoh said:Just a suggestion (born of bitter experience!) on the handle making - if you haven't made one before, a practice run on a piece of scrap (anything will do - bit of construction grade pine, even) may well pay dividends. Ironing out the little wrinkles of technique before attacking the 'nice' wood can save time; it's better to waste a bit of pine than a bit of something nice you've paid good money for. Plane handles look simple, but they have their sneaky subtleties....
My prediction for 2016: The addiction won't subside and you'll have 20+ planes by this time next year (hammer)sploo":1sazpgvo said:This plane buying lark turns out to be a bit addictive :wink:
And... I have a Record #3 on the way. Hopefully the addiction will subside, but I would like a #5 :wink:
No chance. Definitely no chance.Vann":2ivloyhq said:My prediction for 2016: The addiction won't subside and you'll have 20+ planes by this time next year (hammer)sploo":2ivloyhq said:This plane buying lark turns out to be a bit addictive :wink:
Have a great New Year everybody.
Cheers, Vann :ho2 :deer :deer :deer .
sploo":isqyh8kh said:No chance. Definitely no chance.Vann":isqyh8kh said:My prediction for 2016: The addiction won't subside and you'll have 20+ planes by this time next year (hammer)sploo":isqyh8kh said:This plane buying lark turns out to be a bit addictive :wink:
...ebay.co.uk... *click* *click* *tap tap tap* :mrgreen:
LOL. Do spokeshaves and scraper's count as sober, or are they classed as plane purchases?Mr_P":3da1yk04 said:My name is Carl and I'm a planeaholic its been 56 days since I bought a plane.
I can vouch for that. I worked at Qualcast in Horseley Fields Crane works. We turned out thousands of plane body castings of all sizes. Both for Stanley and Record. They were then sent off for machining. Some came back with sand inclusions or blow holes and they were thrown back into the cupola.Stanley UK were using Qualcast for their plane castings a good many years before Record switched to Qualcast (late 1950s). It can't have been many years after the war.
Cheers, Vann.
That thread was from 2015 !I can vouch for that. I worked at Qualcast in Horseley Fields Crane works. We turned out thousands of plane body castings of all sizes. Both for Stanley and Record. They were then sent off for machining. Some came back with sand inclusions or blow holes and they were thrown back into the cupola.
Many thanks for taking the time to confirm this.I can vouch for that. I worked at Qualcast in Horseley Fields Crane works. We turned out thousands of plane body castings of all sizes. Both for Stanley and Record. They were then sent off for machining. Some came back with sand inclusions or blow holes and they were thrown back into the cupola.
