FrenchIan
I bought two worktops laminated from strips of oak. Nicely made - 38mm thick, very smooth finish. Sanded them first, finishiing with 180 grit, then treated top and bottom with two coats of danish oil. (Blackfriar, from SF). Rubbed it in well with a cloth, left for 20 mins, then wiped off the excess - there wasn't much.
Next stage was two more coats of danish oil on the top surface. Applied the same way, but lightly ruubed down after each coat with very fine webrax (1500 grit?). It looked lovely.
However, it's not wearing well. After only two weeks, the grain has raised in places where eg a wet cloth was left, and the original sheen is wearing off. I also suspect there might be water marks appearing.
What did I do wrong? And, more to the point, what can I do to retrieve the situation? Or, at least, stop it getting any worse? (I have assured SWMBO that an oil finish like this is the equal of varnish - if I'm proved to be wrong, I'll never hear the end of it....)
