CHJ
If you need to shift it quickly then a fan heater directed at the spot would help move it into the air to be collected by your dehumidifier I would have thought.
The short answer to that is yes. Tanking only stops the ingress of the water, not the damage it can do. Also to be considered is that once the water can no longer pass through the wall its level in the brick work can rise higher so that it is necessary to tank well above the present damp level. Sorry!
Roy.
Digit":21hz16xu said:The fact that you've started to use the shop again, (cheers!) will in itself improve matters as the air circulation should improve. Hopefully you should see less water in the de-humidifier over a period of time.
Roy.
