novocaine":vw0hast7 said:easier to remove material for balancing than to add it, much like you'd do with an armature. you can static balance it first before fitting to get a better balance and not destroy the motor, set it between 2 points on an arbor is the easiest approach much like balancing a prop for an RC plane, plenty of videos on doing that.
sunnybob":1us9dvck said:no, thats what makes superman fallible.
