Nailer
There's not a lot i can say about it really apart from it does what it says on the tin and it's quite a substantial lump of cast iron .......Oh.......and it's not light :shock:
It comes partially assembled but it takes no longer than ten mins to put the rest of it together.
It's well made and sits flat on the table and any slop in the miter slot is taken out via a couple of grub screws on the slider bar.
As you can see from the pic's everything is adjustable and lockable via the spring loaded levers.
The Jig will cant to the left to 22 1/2 degrees and to 45 degrees at the back there's no scales to read but a suitable gauge will do the job nicely.
Both have stop bolts allowing the return to ninety degrees with out re checking......but i must admit i always do
The micro adjustment left to right has imperial scales but if you were that bothered you could stick a set of metric ones over the top.
Here it is in action.......Look no hands
As i said at the beginning it does what it says on the tin......and you too can be like :norm:......how it compares to the delta one i don't know because i've only seen them on the tv 8)
All in all i'm happy with it and it performs it's job admirably
