Sgian Dubh
An alternative and stronger joint is a common or garden tongue and housing describing precisely the situation where the recess runs across the grain. The term dado, incidentally, is an Americanism that many Americans don't even know how to use correctly, so there's little point in the British adding to mangling of the word's use, ha, ha. A tongue and groove describes the recess following the length of the grain.
Run whatever cutter you have to hand for the housing or groove, eg, 6, 8, 12 mm, and then work a tongue to suit on the end of the matching part, eg, shelf, carcase side, panel, and so on. The joint is stronger because of the increased gluing surfaces and the number of right angled returns that help hold the parts square to each other, and lock the joint during and after assembly. Slainte.
