harryharris
Hi, I am coming to the end of building a deck in Yellow Balau, the newell posts are to be bolted to the outside of the deck frame. The handrail is in an L shape so on one side the post will attach at the ends of the deck boards and at the other side the will go against one run (length ways) of deck board. I need to cut out for the newell posts, approx 80mm wide by approx 30 - 50mm deep, I want neat square cuts.
My concerns are that balau seems to be a bit "fiberous" when cutting and achieving a neat squre cut, do not want to raduis the corners too much ie by drillng and cutting straingts with jig saw. Any advice / ideas offered welcome, my thoughts are to invest in a router (which at some point I want to buy anyway) and fabricating my own jig from plastic etc. However Im concerned the router will not achieve a neat finish because of the properties of the wood - though the fact it is moulded to form deck boards with grooves suggests otherwise?
