I just received some #8 and #0 spiral blades. Not tried the #0 yet, but the #8 did a very quick and clean job cutting this little candlestick from 38mmx38mm stock. My #2 took much longer to cut through 38mm stock for the squiggly thing which I will make into a small table lamp. I chamfered the corners which are now internal so I have a hole to fit the wires through. Just needs a bit of filling and sanding when the glue is fully dried. Had great fun doing these compound scrolls. The squiggly thing was a modified sine wave I created in Desmos graphing app and printed out.
