Doug71
I am building a fire surround for a customer, it will be mainly MDF with some Pine mouldings but the sides of it facing the wood burner will need to be non combustible so for those parts I'm using cement board.
I have not had much to do with Cement Board/ Hardiebacker type board so am wondering the best way to cut it to get as clean edge as possible? I see people just scoring it and snapping it? Will this work with 12mm, can I take some sandpaper to it to get a nice finished edge as it will be painted?
I see some saw blades available for cutting it, could I stick one of these in my TS55, would that give a cleaner edge than snapping or grinding?
I seem to remember (hopefully) at least one side of cement board is smooth enough for painting?
Final problem is I need 2 lengths at about 1500mm long, it seems to mainly come in 1200x800. Do you think I will be able to butt 2 pieces together, fill it and get a near invisible joint or will I have to source an 8x4 sheet? I only need 3 strips about 175mm wide so a small sheet would be more than enough if I can getaway with joining.
Any advice appreciated.
Thanks, Doug
Thanks, Doug
