ok, so i've starting rouging out Mrs KU's otterman using a load of beech block worktops donated to the cause.
I've sized and thicknessed the boards and am now experimenting with cutting some box joints.
The sort of dimensions I'm talking about are 50mm wide fingers that are 25mm deep.
My question is about the safety and accuracy of using a sledge to cut the joints on my router table. I'm considering a "on end" method, with a full table wide sledge and a wacking great big vertical fence to keep the 26" (longest) pieces supported.
I've took some pictures but have been relegated to the netbook and can't seem to post the pictures up onto photobucket
bloody websites not supporting FF on linux :roll:
Assuming the sledge is a viable solution, how many passes should I make to sneak up on the 25mm depth of cut (25mm high, 25mm deep, 50mm long).
Steve
Steve
