RogerS
I'm really seeking clarification of my understanding on this.
I know that when you plane a piece of timber that you need to take recognition of the direction of the grain and plane accordingly. Otherwise you may get tear-out of the wood (if that's the right term).
My assumption is that you need to chisel from the right direction for the same reasons. And that it doesn't matter whether your chisel is bevel up or down.
In other words, if you chisel into the grain then you stand a high probability of ripping up the wood and not getting a clean cut.
Is this correct?
Edit: Oops .sorry ..wrong area. Mods pls move. Thanks
Is this correct?
