Phil Russell
A little project requires me to cut a groove in brass rod and I wondered about the best way to do it using a mini lathe. The rod is 6mm diameter and I need to cut a groove 1.5mm deep x 5mm across approx 25mm from one end.
I thought my first attempt using an HSS cutter travelling directly into the rod was going to work (approx 350rpm, tool set at centre) but just at the last moment the rod snapped. The end of the rod was supported by a rotating centre.
I have concluded that filing is out. I am pondering using a parting off tool, approx 1mm thick to cut each side of the groove first then cut out the centre portion.
How would you do it?
Cheers, Phil
Cheers, Phil
