Chris, here's how I went about a similar job recently. I was making a pair of occasional tables, I sourced a sawn board of 36-38mm thick Maple with some nice fiddleback figure. Call around timber yards in your area and you'll find similar thickness Maple boards, you won't find fiddleback quite so easily but you should be able to track down Maple in what was the old 1 1/4" spec, in sawn board form it usually comes in at 36-38mm. Find a straight grained board and you'll be fine.
I cut it slightly over length and then planed it down (equally on both sides) to 34mm. I left it for a few days to settle and then planed it down to 32.5mm (32mm plus a 0.5mm sanding allowance). At which point it looked like this,
The end grain growth rings looked nice and diagonal like this,
Which means the grain on all four sides of the leg will be consistent, in this case with wrap around fiddleback figure, but even without the fiddleback it's still a pleasing and harmonious consistency from face to face.
I'll rip off the leg stock at about 34mm wide and then plane it back to 32.5mm. This board will yield two or three fiddleback legs from each side. The wood from the centre of the board (which will have "cathedral" grain but in the case of fiddleback boards the centre usually has less or no fiddleback figure), will either get used up elsewhere or run through the wood burner.
