Jacob
What goes around comes around.
That'd work, though you wouldn't need a router. Just take off the arris with a sharp block plane and sand round with paper on a block. A few seconds work.Beau":3c5g1ypg said:Banga":3c5g1ypg said:Hi,
Any tips on the best way to round off corners on small pieces of wood? Size is approx 75X40X3mm. Need a 3mm radius.
If you are doing lots of these would it not be easier to make a wide as possible section 75x40, radius with a router and then cut all your 3mm slices off? Then a quick pass with a plane on the face of each and your done.
