custard":2z8fjw43 said:. Then you can route off as many perfect copies as you like with a copy router bit.
Banga":2i5ow3bo said:I have router but not a router table. Ideally I'd like to make a router jig out of perspex. I have access to a decent laser so can cut with great accuracy. I could cut the whole piece at once. The problem I have is the size of the radius on the jig to get 3mm radius on the piece.Using a 20mm bush. Maybe there's a formula for it? I really need each corner to be exactly the same.
Garno":217hy63w said:custard":217hy63w said:. Then you can route off as many perfect copies as you like with a copy router bit.
I've never heard of one those.
custard":z1kwfg12 said:Garno":z1kwfg12 said:custard":z1kwfg12 said:. Then you can route off as many perfect copies as you like with a copy router bit.
https://www.wealdentool.com/acatalog/On ... m_279.html
Banga":3975pzhp said:Hi,
Any tips on the best way to round off corners on small pieces of wood? Size is approx 75X40X3mm. Need a 3mm radius.
