curved plane
sunnybob
wysiwyg
11 Oct 2014
cyprus
went to the market yesterday, found two crates of old planes, from 2 ft right down to 6" rebate planes as well. most of them not really worth repairing.
But in there was a small plane I have never seen before. the base was convex curved side to side, and also the blade, but the blade was a bit wider than the base curve.
I cant work out why you would plane a hollow.
Any body know?
Any body know?
Architectural joinery. Staircases (handrails) in particular. And other trades - music instruments etc
handrails are the other way. This plane cut hollows, not rounds.
think groove, 2" across but fairly shallow, 1/4" maybe at the deepest.
The curve was shallow enough that when i first picked it up i thought it was a normal plane that had been very badly abused. only checking the blade matched the base made me realise it was a special tool
Bob, maybe you're thinking of very simple handrails, like a modern 'mopstick' - but historically they were much more elaborate, with multiple curves, in and out, curving round elegantly.
It could also have been a pattern maker's plane.
Must have been one of those. Once I realised the base was supposed to be that shape, it was in quite good condition. Dont suppose something that specialised got used very often.
I recall a Fine Woodworking article where a sculptor made a special plane for the particular curve
on a large geometrical sculpture.
I you understand enough,you can make your own specialised planes for tasks.
BugBear
Don't think it's musical instruments, unless it's convex both across and along the length of the sole. That's the standard pattern for carved top instruments. I can't think of a use if it's just convex across the sole.
Gutters or large architectural mouldings.
Sorry, I meant as a use in musical instrument making. Every such plane that I've come across has had the double convex sole.
Convex end-to-end planes are used to saddle the seats of Windsor chairs. I think a few makers use ones convex in both planes - end to end and side to side. Some just use a large gouge and then a series of shaped scrapers which is the most direct approach IMO.
whiskywill":tzvfblhw said:
As Jacob has already suggested, they are used by musical instrument makers and are still available including these pretty Veritas versions. http://www.ebay.co.uk/itm/Veritas-Detai ... io-Uiy3SJQ
The musical instrument ones are notably different - in size; if you follow the linked you posted, you'll
find the blades are a teensy 3/8" wide.
I don't think you'd get very far using the OP's plane with its 2" blade on anything as delicate as a violin plate!!
BugBear
wow, dint think I'd start a riot!
Cant remember if it was curved in both planes (lol) or not. If it was, then front to back must have been very shallow or i think I would have noticed it.
The blade was not 2" wide, from memory i would guess at 1 1/2".
Oh, OK, you said 2" wide, 1/4" sagitta earlier.
No probs.
BugBear
ah, went back to read my earlier post and I see the confusion. The PLANE was about 2" across, not the blade.
BugBear
Double bass?
Still would be curved in both directions, I'm just being facetious
