Jacob
New Luddism. Awake and resist!
Is there a coach bolt (square bit of shank) but countersunk with no slot so it'd fit flush with the surface? Say 5mm dia?
5mm threadI’ve certainly seen bigger ones over the years but never that small.
but not countersunk.Screwfix do m6 coach bolts
once get desired bolts! Get a socket that fits heads and measure outer diameter of socket then shallow bore out holes with a forstner/flat bit etc that matches outer size of socket to required depth, once done have options of using a ratchet or power tool that way flush fitting done that many times.Is there a coach bolt (square bit of shank) but countersunk with no slot so it'd fit flush with the surface? Say 5mm dia?
All the coach bolts around here don’t have a slot though the head is slightly domed so you would just drill a recessIs there a coach bolt (square bit of shank) but countersunk with no slot so it'd fit flush with the surface? Say 5mm dia?
