Yesterday I was faced with cutting a new primary bevel on a plane iron. With the state of my back I could not face a long hand grind on the diamond stone. I have an High speed grinder but I am not that keen on hollow ground bevels. Now this is the crude bit, I have a belt sander that can be mounted upside down, I have an eclipse honing guide, I thought if the wheel of the guide rolls ok on the diamond stones when I push it, it should also work ok when connected on the moving belt. I set the guide for 25 degrees, put on a medium grit belt, set the slowest speed and positioned the plane blade as close the end of the belt were it is still supported by the plate underneath. The reason I positioned the blade there is that the belt is much flatter compared to say in the middle where the edges of the belt have a tendency to curl up. I lowered the blade and the guide down on to the moving belt (belt rotation moving away from the blade), and every thing seemed quite stable, after about 3minutes I had a resonably flat new bevel. A 3 minute grind on the diamond stone and it was dead flat across the whole face. I am surprised this worked so well. However if you dare try this check that the belt it flat right across when it is running, unless of course you want a cambered blade.
