Hello,
I have bought a 26" 7 ppi crosscut saw and I have sharpened it. I have watched multiple videos on sharpening both rip and crosscut saws (Paul Sellers, Frank Strazza, Wood By Wright, etc.)
I have used around 10° of rake and 12,5° of fleam. I will cut mostly hardwoods. The saw has a relatively thin kerf and it cuts straight. The saw was first jointed to level, because there was a 2,5 cm hollow in the middle, so I had to joint and sharpen multiple times not to lose the tooth pattern completely. I have taken care to have almost all teeth at the same height.
When I compare my saw to this Badaxe 8ppi, I have cut a similarly thick board of dry oak and my sawing speed was 4-5x slower when taking full strokes. When cutting silver fir, it was also slow.
The saws that I have sharpened rip cut relatively fast.
What are some good tips to make the crosscut saw cut faster? The finish quality is not that relevant, because I will always use the shooting board to make everything square and clean.
I do not have an option to send the saw to someone who actually knows how to sharpen it, unless I want to send it to the USA, that would make it too expensive. When I started woodworking, I took my all plane blades and gave them to a local professional sharpening specialist who sharpens table saw blades, drill bits, etc. and all he did was he used a machine to sharpen them at the required angle. I do not need to say that they were not sharp enough from the grinding wheel. In my country I have not heard of anyone still using hand saws, so the sharpenings skills might be also gone.
Thank you for your tips.
