Crack in chair base
jb94
11 May 2024
Rotherham
Annoyingly the lovely chair I spent the last few months making has developed a crack in the base…
Seat base is Laminated and joined with 3/4 inch dowels
It was properly dried wood ~12-15% moisture initially measured on my probe before making the chair.
The room it’s in is ~ 50% rh and doesn’t fluctuate much no drying of clothes etc. The garage I made it in is also at ~50%rh has a dehumidifier set to this target rh all the time.
I know it’s positioned near a radiator but this radiator is rarely ever on, and when it does it’s warm at most.
I think the crack has extended and widened slightly, but the chair is still rock solid.
I would have just put a bow tie in but it’s in an awkward spot between the spokes for the back.
Whats best course of action? I’m worried it’ll continue to split.
    2.4 MB
    1.6 MB
    2.4 MB
That's a lovely chair, sorry to hear about the splits!
Looking at the pictures I think it is a shake in the timber, ie the defect was there before you made the chair. There look to be others in the chair seat, all the small black lines. Without these the limited movement in the timber due to bringing it inside would likely have been insufficient to cause a crack/split, but this one has widened as there is nothing to stop it.
As you said a bowtie/butterfly would be the ideal solution, with the access available a deep one from the underside may be the only option. Drilling and gluing in a dowel from the edge would give some structural strength to the are but not sure it would do much to limit more movement.
Fitz.
They are not laminated they are edge joined boards and inherently weak. They also look too thin and the cracks look inherent to the piece of board - others have inherent cracks too.
Not much you can do except perhaps glue/screw some battens across from side to side underneath. "Butterfly" would look nice but probably weaken it further.
Have a look at some Windsor chairs. Mine here has seat varying from 40 to 35mm thick, but bottomed out thinner in parts. It's one solid piece of elm, uncracked and probably 100+ years old.
"Laminated" means layered, like plywood, with crossing over grain directions, and is very tough.
Pity, as it looks good otherwise. It's a learning experience!
Nice chair.
With that variety of cracking (probably due to inherent tensions in the particular bits of timber, as others note) I've found that the best solution is to let the tensions out (i.e. don't try to draw the crack back together) leaving the piece until any other such cracks appear (hopefully they won't).
To stop crack spread, though, drill a small 'ole at the end of the crack that's the narrow-to-nothing end, which will usually stop the crack creeping further.
When its stopped doing its cracking, push a gluey wedge into the crack (without making it crack more) and make/locate dowels/plugs in the small anti-cracking holes. Do your best to match the grain directions and colours, of the same kind of timber.
If the crack is not wedgeable with one piece of wood (and yours isn't 'cos of the wriggle in it) you can successfully stuff the wonky crack with successive pieces of gluey veneer, wood chip or other smaller pieces (again, of a matching timber/colour/grain direction if possible). Hide glue is generally best. Chisel, scrape and sand it all to shape once stuffed.
You'll inevitably be able to see the mend - but in some ways it adds to the character of such pieces. :)
I've not, though, needed to mend a chair in this way. Chairs have some large stress applied to them unlike, say, a cabinet or bedside table. Nevertheless, the above mend might suffice and be strong enough as well.
I would run some glue in the crack with a slip of veneer and bring it together by clamping two blocks for a G clamp. Another approach might be a pocket hole screw or two under the seat. You never know.
