Covering Gaps in Plywood Board Walls
scruffmeister
22 Jul 2023
Woking
I'm boarding my workshop with plywood, prior to painting. I would like to cover the gaps between boards with tape as this seems a better approach than using filler which will likely crack as the wood expands/contracts.
Can anyone point me to a tape that will stick well to wood and can be painted over? I don't mind if it is slightly visible through the paint layer as I think this will look better than board joins.
Also happy to hear any other ideas for dealing with the gaps...
Thanks!
Caulk all day, one of the ideas of plywood is the alternating grain orientation limits seasonal movement.
Do you need to hide the joins? If you are using full boards or site lines look good, why not run a slight 45 degree chamfer on the board edges and make it a feature.
Colin
You could just use a trim on each joint, either make them from wood or buy the plastic / metal ones.
This will give quite a quite a characteristic look to the whole project. I believe there was a product in America, called "Beaver Board" used for walls and ceilings that made use of this type of fascia cover strip at the junction of each board. And it does impart a certain look. :unsure:
I used 12mm cheap ply and just made sure the edges butted up square. Then I gave the walls two coats of white emulsion. That was 12 years ago. Still looking good.
Hi Scruples,
How are your walls made? or Did you use plastic vapor barrier between the ply and the studding?
If you choose caulk, it sometimes shrinks into the gap, so if you are really fussy, plan on doing it twice, one week apart, to get it as flush as possible.
Nice.
    268.9 KB
Thanks!
In one of my past shops which had OSB sheathing on the inside I simply used a latex caulk. As already mentioned the joints were near invisible after painting. Even less noticeable once you hang things on the walls.
Thanks!
No help to you, but I use T&G chipboard flooring boards. Cheap and easy to fix, and you get a nice flat surface with flush joints. Also if you use them horizontally and off set like bricks, then you don't have to worry about the spacing of your uprights.
