woodbloke
Decided to put a handle on and old quarter inch mortice chisel, used a bit of elm for the handle. The back of the blade was the longest part, bent like a banana so it took a long time to get flat, should work OK now tho'
I made the little knife years ago but the corner of the blade got chipped so I've reground it and honed it again. I read somewhere that an old cut-throat razor has the finest steel you're likely to find anywhere, this is what the blade of the little knife is made from....certainly takes and edge :shock: Handle is a lump of ash with the blade epoxied into it. Going to use it to clean out the corners of dovetail sockets - Rob
