Coronet Major - query
disco_monkey79
5 Oct 2009
Hi
I'm looking to upgrade from my entry-level lathe. Coronet majors seem to be well regarded, so I am contemplating one.
I'm not sure how much the design varied over the years, but I'm referring to the ones where it's a steel bar between cast-iron feet. What stops the tail stock assembly from spinning right round? Is it simply the "pinching" action from being tightened? Or is there a groove or similar machined in to it?
Anything in particular to be on the look-out for, with these?
Also, the one I've seen looks like it has a non-revolving centre in the tailstock. Would it be a major faff to change to a revolving centre, or are these machines an akward size?
Hope that made sense.
It's been a while since I saw one but memory says there is a slot along the back of the bed and the tailstock has a spring-loaded plunger to locate it, which can be released to allow it to swing down out of the way. As I recall the tailstock is bored MT1 so you can swap centres. There's probably lots of info on lathes.co.uk
Just to confirm normancb is quite correct, there is a slot at the back of the bed with a sprung plunger. The plunger has a knurled knob on a screw thread which I often find unscrews!! The pressure of the spring is adjustable.
I've had a coronet major all my turning life and am generally happy with it, with the head turned you can take up to about 23inchs.
However, there are three drawbacks
1 - You really need a speed control, I started without and found that turning a 23inc disk at the lowest speed - 400 revs gave an edge speed approaching 30mph!
2 - The distance of the motor from the 'axel' does mean that there is a certain amount of 'bounce' o you have to be careful with your speeds.
3 - The securing pin on mine does not centre the drive end to the tailstock so I always have to do a 'Kis' and then re-check with a longer section of wood held in a chuck.
Nonetheless, a good piece of kit.
Phil
Thanks all. I bought it, so looking forward to having a go on it. It's certainly a lot sturdier than my little Clarke jobbie
Hmmm, so... It doesn't want to work. If I press the start button, the motor tries to start, but immediately stops.
I'm using it on an extension lead)(as I do for all my woodworking equipment). Is the motor too powerful for this?
Or could there be something else wrong?
Capacitor maybe?
If it wss a supply probkem, Id have thought it would either work blow fuse / trip out. I doubt a lathe would have a very big motor.
Disco
If you go straight to getting variable speed control you should bypass this problem as they system comprises a new mote and control. I had mine from www.haydockconverters.co.uk and have had no problems with it for 10 years or more. (other suppliers are available!!)
Phil
Thanks both.
Will get the capacitor tested, and see if I can get the beast running. Then I'll look in to the speed control jobby.
