Hi - I am an ardent Coronet user and restorer in Sunbury. I am currently using a Coronet Major MkII I have restored with all the trimmings/add-ons.
For the purposes of this post I am assuming that your Consort has a headstock spindle with a 7/8ths x 16TPI thread on it.
I too had the quandary of fitting a suitable chuck to my Major; after taking advice from a few other users I settled on the Axminster Club SK100, but if you can afford the heavier version (SK114) go for that.
You will need an adaptor to go from Female 7/8th" x 16TPI down to Male 3/4" 16TPI. I manged to obtain a nice brass job from a guy on EBay, and it all works fine as long you make sure everything is really well tightened on the headstock spindle - if you don't and there is
any movement, you will end up with off-centre bowls; interesting but annoying (esp. if you're making boxes). You can see the set up in the attached pic (I hope). Ignore the steel washers you can see between the fitt
View attachment 91381ings- that's another story!
I chose the Axminster mainly because it's actually made at their factory in Devon, and beautifully made at that. Most other makes (I fear) tend to be imported from China (despite claims to the contrary sometimes) and are frankly not as accurate in manufacture. The range of Axminster jaws available is substantial (
Jaws for Axminster 100mm Chucks - Chuck Jaws - Woodturning Chucks - Lathe Accessories - Machinery Accessories - Accessories | Axminster Tools), although a tad pricey in some cases. Worth it though if you can afford it.
Hope this helps.
