Copy cat clock.
gwaithcoed
23 Feb 2005
North Wales
Seeing the Clock Project by Dom inspired me to have a go.
I had several clock dials, chapter rings, quartz movements etc. that I had been given some years ago but had done very little with them
I didn't have anything nearly as good as Dom's skeleton clock,but I sorted out a nice dial and went from there.
That's when the problems started. I wanted it to look like Dom's but as the dial was smaller I had to alter the proportions.
This meant that a door was out of the question.
I tried to make it a little shorter but that didn't look right. Then I found a barometer that I could put in the lower portion and below it a thermometer
That looked better, and so I started.
I didn't take any WIP pics as I used all of the ideas from Dom's thread (hope you don't mind Dom)
Anyway they would have been MIP (mistakes in progress) I couldn't believe how many I made,mostly with my measurements.
The final upshot was that the barometer chosen would not fit in the lower portion.
I then found a smaller one which would fit but as this had a thermometer incorperated in it the original idea of a seperate one was out.
I did feel at this stage that I should bin the whole idea as it wasn't coming out as I had planned.
I called in a second opinion (SWMBO) and she said she liked it and to carry on.
This is the finised item and I am more pleased with it than expected.
[/img]
Hope you like it
Alan.
I like it a lot Alan, and the C.P.O. has just spotted it over my shoulder
and said "Oooh! That's lovely" :wink:
Very nice gwaithcoed. I'm glad if the blog was of some help. How did you joint the quaters? The finger/glue joints I used were a big headache for me and 3 mistakes meant I nearly ran out of material towards the end. I had to salvage these mistakes to make the door. As for measuring mistakes like I said in the blog I drew a full size plan so measuring mistakes at the beginning required only a rubber to fix. Not sure what you mean about a door not being possible. On my clock the diameter was around 9 inches but I've used the same technique on other projects to cut arcs with a diameter as low as 4 inches. Nice finish though. What did you use? :D
Dom asks
Eventually with biscuits,I did try finger jointing but had too much tear out.
Its just that I thought the carcass would be too narrow for it to look right
What did you use?
3 coats of danish oil.
Thank again for your WIP pics, wouldn't been able to do it without them.
Alan.
Hello Martin
Where do we buy the clock mechanism and face
I was very fortunate to have mine given to me. Dom had his skeleton clock from Axminster.
The clock face on mine has a hinged glass but I haven't seen any like this on the sites Pete has shown.
Still got some left and am now doing one in mahogany for a neighbour.
Alan.
