Converter or inverter?
lastminute
26 Apr 2009
West Yorkshire
Thinking about buying a school Startrite 3 phase bandsaw in good condition, whats the best way to power it, a Converter or Inverter?
Whats the difference? Is it just a matter of wiring the unit and pressing the green button?
Would changing the motor to a single phase be an option? choices of the 351, 352 and 352s...which is best?
Thanks for any help.
Gerry
Have a look here for info.
http://www.powercapacitors.co.uk/Power_Capacitors_Site/IMO_Inverter_Downloads.html
A Startrite 352 of any type would be fine. The only difference with a 351/2 is that the 352 is two speed.
Bandsaw motors tend to be smaller and of about 0.5 to 1 hp so a smaller digital converter should be OK. Theres lots of literature available on their site but its become a bit more difficult to access.
351/2 are eagerly sought after so maybe buy all three and resell two.
regards
Alan
352 owner.
There is a sticky thread at the top of this page - use of induction motors in the home workshop - written by Bob "9 fingers" which contains a link to his article telling you everything you might want to know and more about such questions.
Hope this helps
Graham
My recommendation would be to buy any 352 that goes for a reasonable price - easy to adjust and built to outlast the owner!
Mine came (indirectly) from a school, with 3-phase motor. As I had a 1hp single phase motor to hand, just swapped them over. It only involves removing one wire if you are a real cheapskate, because you can parallel the 3 overload contacts to give the current rating needed. But obviously better to replace the start/overload unit with one of the proper current rating for single phase. If it's one of the more recent ones with external switch, it's a doddle. Mine had the switch built into the column, which is a bit more tricky because only certain units will fit.
But you end up with a superb machine. Only one snag - dust extraction is lousy :(
