Continental European woodworking tools
Part two on continental tool traditions: joinery planes.
This part likely isn't quite as interesting as the first, as it seems to me that there are fewer differences compared to the UK.
- Simshobel
This is the basic rebate plane. Basically the same as in the UK, except that the iron isn't usually skewed. Not much to say about this plane, other than that the UK version is probably superior. Personally I prefer a WS78 without a fence.
There is also a version without a sole in front of the iron which works as a chisel plane, but I would just cut up a worn out one instead.
- Doppelsimshobel
Same as before, but with a chipbreaker for finer cuts. The mouth is also adjustable. On the one hand this is necessary in order to take out the iron, but it also allows a tight mouth for little tear out. On tough cuts I find it to be a bit flimsy, as the wingnut can only hold it so well. I think of it almost as a rebate smoothing plane.
- Falzhobel
This is just a moving filister plane. It has fences for width and depth. The one in the picture has the iron square to the sole, but most of the ones I've seen have had a skewed Iron. I really like this plane for crossgrain rebates, I find it much easier to use than my 78 or Record 050. The big long crossgrain nicker is easier to adjust than the tiny nicker on metal planes. Otherwise, similar planes used to be made in the UK.
I've also seen wider versions with a fixed cutting depth that are for panel raising.
- Grundhobel
This is just a router plane. It has an angled iron like a 71, but has no fine adjustment. It works fine, but I much prefer my Record 071.
- Nuthobel
The plough plane. They used to make basically the same thing in the UK. It works fine, but I usually reach for my Record 050.
I've also seen versions with a fixed depth and fence that could be part of a tongue and groove pair, or fixed at the standard setting for making doors for example.
- Grathobel
This is the sliding dovetail plane. As far as I know, this wasn't common in the UK, but here it was a standard joinery plane for a professional woodworker. It's like a moving filister plane, but with a sloped sole.
This plane is used in conjunction with the 'sliding dovetail saw' (Gratsäge) to cut the corresponding housing joint. As far as I know, this is the only western pull saw. This is necessary for making stopped housing joints, as you pull the sawdust out of the cut. You chisel out a small portion on the stopped end, and then you make cuts by pulling the saw towards yourself with both hands. The depth of cut can sometimes be adjusted at the blade. The waste is then chiseled away, and the joint is finished with a router plane.
There might be more planes I missed, but this is what I can remember off the top of my head.
I personnaly use the Falzhobel for crossgrain rebates, and I use the Grathobel as there is no UK equivilant. Otherwise, I find I mostly prefer my WS78 (without fences), my Record 071 and my Record 050 for these jobs.
    315.8 KB
That basic rebate plane can be more useful than it first appears. I converted one to be a plough plane. Granted, it only does a 6mm by 6mm groove, 6 mm up from the edge of the workpiece, but that is a perfectly reasonable groove for most of the things I make. I had the 18mm plane, turned the blade upside down and sharpened it (it's 6mm wide at that end), then routed a 6×6 rebate on either side of the base of the plane. I chiselled out a couple of spaces for some plasterboard cutter blades, sank a couple of threaded bushes in to screw a simple plywood fence to, put a chisel blade cover over the 18mm end of the blade, and voila.
I think I paid a tenner UK money all told (but this was a few years ago). Because it is double sided, you only have to swap the fence over if you want to plane the other way. That's a total pain on my Stanley plough.
    251.5 KB
There is actually a really nice alternative. Marples made a number 4 and 5 beech plane with the adjustment of metal Record/Stanley planes. They turn up on eBay occasionally and I can really recommend them. In fact, I intend to make some other sizes using them as a template. They are so light to use and a real pleasure.
Yes the 2690 and 2691 from the early 1960s. I have replaced the basic blades with Luban iron and cap iron on my pair and they are a joy to use.
There's also something similar out of Germany, the ECE Primus plane. They have depth and lateral adjustment with a system that is completely different to the Bailey design (and possibly better suited to a wooden plane).
That being said, they're not very common. I've only ever tried one and I found it a bit fiddly. I reckon that most woodworkers were used to adjusting normal planes and didn't see the need for the extra adjustment, and those that did want the extra adjustment got Bailey (or now Rali) planes.
Personally, though I appreciate my wooden planes, and I know that they are irreplaceable for certain tasks, I prefer my Record planes for most jobs.
In Finland, Sweden and Norway our planes are traditionally fairly similar though different from both the German and the English tradition.
Professional planemakers were pretty much nonexistant. Craftsmen made their own planes until the second world war. American style cast iron planes were brought home by returning emigrants. Starting in the 1890-ies it was common to work a few years as carpenter or joiner or logger in America to earn money for buying a smallholding or building a new barn at home and pretty much everyone brought home a plane or two and an American handsaw or two.
Anyway this is how it was:
-Custom made scrub planes were a rarity. Normally one would use a worn out smoother with a cambered single blade.
-The smoother was made just like it is in Germany. With a horn. Usually a double blade bedded at 45 degrees. The very old ones have a single blade.
-The jointer had in the old times a body of equal height along the full lenght. Often with the handle offset sideways. Usually with a double blade though the very old ones have a single blade.
-Ox plane with crosswise handles for two men. Could be ither double or sigble blade more or less cambered or straight. Used for all forms of rough planing. You often lay the board on a long low bench and sit on top of it stradding the bench and the board. Work the plane back and forth between you.
Theese old planes exist side by side with American style iron planes to this day.
-Rebate planes similar to German or English single blade shoulder planes. Usually the blade var straigh across but it could be skewed.
-Rebate planes with fences of various sorts. Many had fixed fence for rebates of standard sizes though some had adjustable fence.
-Profile planes are usually of the continental European type though the English type is also known.
-Handsaws were almost unknown before 1880 and fairly rare until the 1920-ies. Back saws were unknown except the occasional specimen brought home from America or England. Joiners used bow saws with a woodenframe and a wide blade. Theese old style bowsaws were fairly common until the 1970-ies or thereabout.
-Chisels are fairly similar to their English and German counterparts. Except the very oldest whose blades often taper in witdth.
-Braces were usually made from wood in one piece until factory made braces became common in the early 1900-s though the old type lingered on untilafter the second world war.
-T augers and breast drills were used a lot. Before 1890 most augers as well as drill bits were hand forged of either the spoon type or shell type depending on region. Some use those old style bits and augers until modern times.
-Knives are used a lot. To a nordic joiner or cabinetmaker a knife was and is an important tool.
-Axes and hatchets were used a lot for all sorts of roughing out and for cutting boards to width and thickness. Each region har it's own style. Even today axework is important to us.
Very interesting, thanks! What do you do with a knife?
Stanley US made some similar planes, although the Marples planes are certainly attractive critters: see here. I can attest that they're pretty light as well. There's always the problem of warpage, of course.
Thanks for posting the link which I hadn't seen before. Interesting to note the return of the "high knob" on the final American products, which brings us right back to the European plane horn . Woodworking tools do evolve.
Part 3: Saws
When it comes to continental style saws I have less experience and I think that there are two reasons for this. Personally, I prefer British style saws, or even Japanese saws, so I've never much used traditional European saws. The other reason is that many local woodworkers seem to have come to the same conclusion and have abandonded the traditional saws in favour of Japanese saws.
Gestellsäge (frame saw)
The basic saw for woodworking is the frame saw. The vertical parts are usually made of beech, and the long horizontal part is made of a light softwood.
These existed in various sizes. The biggest (85-100cm blade) were used for "fausten", which means making big rip cuts at the bench holding the saw with both hands. For joinery you would use a smaller version (about 60cm blade) with finer teeth, and there is also a version with a narrow blade that is used as a turning saw.
I find it interesting that these saws were almost universally filled for rip cuts. I've never seen them filed for crosscut, with the exception of saws meant for cutting firewood. It seems that the woodworkers instead just varied the pitch of the teeth to achieve the desired result.
For rough cuts it would be "auf Stoss" (on the push):
For joinery it would be "schwach auf Stoss" (weakly on the push) for a smoother cut:
For very smooth cuts (with a gent's saw for example) it could even be like this:
Otherwise, fine joints were often made with variations of a gent's saw, often with a swivelling handle:
I never much liked these saws and the can't hold a candle to tenon saws in the UK.
Panel saws and tenon saws also existed, but they don't seem to have been as common.
Links:
https://www.holzwerken.de/werkzeug/saegen1.phtml
https://www.holzwerken.de/werkzeug/saegen2.phtml
    79.4 KB
    63.3 KB
Scotland would like a word about all this English chat...
Good point. I used the term English simply because I consider Scotland to be a totally different entiety whose local varieties are largely unknown to me. My surces are all English and I have been taught never to assume that the Scots and the Welch do things like the English.
I have seen plenty of that type of bow saws with crosscut teeth. Usually Scandinavian style crosscut which differs from the crosscut commonly used by Brits and Germans.
Scandinavian crosscut has the same slope on both sides on the teeth so the cut equally in the pull and the push stroke. It is better for accurate splinter free cuts in softwood.
I am currently looking for a new blade for mine. The teets nees a reset and they just break.
If your teeth break on resetting it might be because you are bending them from too near the base. I had this problem with a setting tool and had to file the angle on the "anvil" to make it bend the tooth from nearer the middle, further away from the base.
I've seen similar saws, but I got the impression that they were for firewood (or maybe rough stock breakdown).
I wondered if the scrub plane featured more in Europe because they had more forestry and did more timber building with un-machined stuff, log cabin style. Scrub plane just the job for cleaning up, jointing, after axe and adze.
Perhaps why Stanley introducing a metal scrub in N America where there is also more timber and N European immigrants.
Record did too but too late for the UK market and it never caught on.
The following is a wiki link to industrialisation in Germany which usefully compares the UK and German industrial revolutions. Germany industrialisation. The main message is that Germany lagged the UK for several decades, only beginning to catch up from around 1850-1870.
The UK was a complete and coherent nation for centuries with few internal barriers - legal, customs, communications etc. Germany was a set of separate states until unification in 1871. Much of its economic base was feudal in character and craft based.
Using iron or steel requires a sophisticated, integrated technological base (mining, transport, refining, casting, fuel, etc. As late as 1870s Britain produced over twice the steel of Germany.
It would have been a very expensive material only used if carrying very clear benefits over alternatives. Wood was cheap and techniques for working it established over millennia.
I know there are other views, but using steel and cast iron in making planes allows for a more consistent product with far less variation in quality and accuracy compared to wooden craft created alternatives - hence its almost universal adoption as the material of choice today.
