hunggaur
hi I have a work shop that is built out of concrete blocks with insulation in the cavity and a flat roof the roof void has been filled with insulation.
The whole workshop has been lined with 9mm laminated melimine boards.
However I have started to suffer a problem with condensation on the walls, ceiling and the machines.
Should I put In additional air vents to get greater airflow or should I seal the room more to limit the amount of air flow.
If I need additional air vents should I put a couple at low level in the door and one at high level in the wall.
Jon
Jon
