Thank you so much to everyone! There’s a lot of information from everyone so here’s the plan (I think):
1. Going to use the Bosch Cyl-9 with the rotary 18v drill
2. Or Use it with the hammer function on the larger hammer drill and then see if that works.
3. OR Grip fill is coming today so will use that to put a timber piece on and then screw into that for the clamp rack to fit on.
4. OR Plywood is now on order so will use the adhesive to put it on batons (4x2)
last thing I want to do is damage the concrete on the outside or in!
I will consider buying a SDS drill and making the holes that way if it’s possible!
I will also remember to keep the drill bit cool.
if I have to use adhesive to get battons on and screw 18mm plywood onto that....will it be strong enough to hold loads?
thanks so much everyone!
