Oldnut
I like the sound of a previous suggestion, holesaw through the floor to fit 4 or better 6" plastic pipe, match the pipe to the 4 mounting feet, place lathe over the 4 pipes but raised up say 3" put long studs through the mounting holes with nuts above and below then mix and pour grout into the pipes, few days later remove the raising packing, lower the lathe with the bottom nuts, when as low as possible use an accurate (proper eng level accurate to .0001") level in both directions on the bed, especially accross the bed at both ends of the bed to remove any twist.
