Lots of good advice already. The only thing I can add is to ask how you're measuring the line? You might get better results by NOT using a tape measure - e.g. if you want several pieces 'the same length' of 300mm, is it more important that each one is 300mm, or is it more important that each one is the same, and maybe 4 at 302mm is OK... in which case, don't measure, use a stop. If you need to accurately 'match' something, can you use that something as the measure? e.g. can you place the first piece on the saw, touching the blade, then set a stop, and then use that stop to cut your next piece?
You definitely need to account for blade kerf, and knowing which is the 'waste side' of your wood, and knowing which side of your line to cut, is critical. I find it helpful to mark which side is 'waste' when I mark the line. If you're chasing real accuracy, then a mechanical pencil can be more accurate than a regular one if not regularly sharpened, and a marking knife can be more accurate still.
