shinobidef
New member
Hello all,
I’m new here and also completely new to woodworking – the last time I ever did any wood cutting was making the obligatory balsa wood plane at school about 25 years ago! I supposedly hail from a family of wood sawyers so hoping there’s some kind of ancestral knowledge I can tap into
I’m converting a camper van and due to budget reasons and a particular look I want, I’ve set myself the momentous task of doing all the woodwork myself, including the kitchen cabinets as a first task. I’ve bought myself a Kreg jig and face clamp, 4 corner clamps (although not sure if this was a good idea as seem too small for the wood I’m using), and a router with bit set. Despite pocket hole joinery being for beginners, I had to get my boyfriend to show me how to use the jig and drill for about an hour! I’d also never used a jigsaw before yesterday so I've cut and laid out the face frame but that's as far as I've got.
My reason for getting the router is that I was planning on attempting dove and tail joints for the drawers, but as I’ll be using ply, I’m not sure this is going to be possible. I was also going to use it to make some freehand designs on the front of each drawer panel or using a tongue and groove system, but I don’t have a router table so not sure if buying one was a bit pointless at this moment.
I’m going for the stick frame technique with ply panels. I know they cupboards are going to look rubbish inside but the main thing is here making something very light, strong and that works with the rustic look we’re going for. I have a 27mm, 2 metre oak worktop that needs to sit on the top of this.
I’ve attached a drawing with my cuts and where the plywood is going. My face frame is made out of 18x34 and all the batons you see behind that are 25 x 37. I was hoping to get away with 3mm ply for the inside panels, but maybe I’ll need to use 5.5mm. The ply will sit front to back and rest on the long orange batons, the side panels will sit on the top and bottom green panels.
What wood and thickness do you think I should use for the door fronts and drawers? The doors will sit flush with the face frame and I’d quite like to use those black antique tee hinges as the whole camper is supposed to look very woody and rustic.
Am I right in thinking that for drawers (so the first and third section) of the cabinet, you need to attached the ply inside panels to they’re flush with the inside of the drawer section (for mounting drawer runners)? This is a bit of a problem on the ends as you can see I’ve got the ply sat on the outside so the end grain goes right into the face frame, but if that’s right about the panels being flush inwards, then I’ll need to change the left side panel (or double up on panels).
I’ll have a toe kick but the second section in won’t have a floor as the gas bottle will be in there and it needs to sit a minimum of 5cm below the bottom of the door opening. The toe kick Is 80mm high but haven’t quite worked out how to build this in yet.
Any tips/help would be appreciated! I’ve watched loads of vids and have a couple of books but can find very little on stick built cabinetry.
Thanks!
Thanks!
