Zeddedhed
I thought you might all like to see a recent commission (sorry, that sounds pretentious) for a client - a 7 sided coffee table.
The table is made from Euro Oak and measures 400mm wide, 700mm long and is 450 mm high. The boards are 27mm thick.
Essentially the table is half of a Dodecagon plus the top, so seven faces.
This gives a bevel angle of 15 degrees (or 75 degrees depending on how you look at it)
First task was to do a quickie CAD sketch to work out the relative sizes of the pieces.
Then a quickie MDF mock up to make sure it was clampable etc.
