Coffee table, comp entry
seanybaby
18 Mar 2007
March, Cambridgeshire
I have designed a new coffee table for the competition and also because my parents want a new one. I've only been woodworking for less than a year, so i thought i would keep the design really simple.
It was first time using CAD so not too sure if the drawing is correct, but i understand it so that's all that matters.
As you can see it's a large chunky table comprising off three panels and a shelf. The panels fit together with dovetails and the shelf has through mortice and tennons with wedges. I will be making it out od Ash and the shelf with be Iroko.
Still not sure on some of the measurements yet though so they might change. Gonna have a go at producing in SketchUp.
Sean
Looks interesting Sean.
Assuming your dovetails are through, bear in mind that when you put a finish on, the end grain will colour darker than the rest of the table.
A light coat of sanding sealer should stop that, unless of course you want the contrasting effect.
Dom
Cheers for the tip Dom.
The joints are part of the design and i want them to be the dominant part of it. The only thing i'm worried about is getting the dovetails pretty tight.
Hi Sean
May I suggest a bigger gap between the top and the shelf... If only to help
when it comes to apply the finish.
Hi Dom
I bet my sign is bigger than yours, LOL
Regards
Paul
Hi Paul
Welcome to the forum.
Neil
Here's your image: -
Ah it's the man, you didn't do anything wrong Paul "The Spamulator" got you, until you've made a few posts it will not allow you to post pics.
Dom
I have been busy with SketchUp. I must say it's very good for getting a visualization on what i would like to make. Also my mum can understand this rather than a 2d CAD drawing.
This one gets my vote - out of all the entries this was the one I'd be most likely to build myself (It's not a match name thing at all :!: )
The wedge tenons look to be in danger of splitting the ends, unless the grain is not as per the sketchup textures. On a similar point, did you mean the grain of the top to run along its length?
