Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
In case this helps someone else...
I am fed up with the noise, vibration, runout, etc., so, after Christmas, I will replace as many bearings as I can, and the two drive belts. In each case I'll buy decent bearings rather than the cheap ones fitted. SKF ought to improve matters.
But the Clark manual only lists their own, strange part numbers, even though, as far as I can tell, the bearings are very standard (so good ones are cheap!).
To help anyone else considering the same task, here is a conversion table of the parts I have identified as having generic replacements. These probably work for other similar drill presses too.
Bearings:
Clarke__________ Std._______ Notes (int+ext+thick in mm)
BRG60202_______6202_______ Idler pulley (15x35x11)
BRG60203_______6203_______ 2 off, Top pulley bearings (above quill) (17x40x12)
BRG802024______6204_______ Main quill bearing (20x47x14mm)
BRG60201_______6201_______ Top quill bearing (12x32x10)
Belts (Clarke: DD16105011):
10mm x 6mm x 635mm (originally 3/8" x 1/4" x 25")
Note: These are as fitted, but 25 1/2" belts (648mm) are also available,
which may make speed changing easier, depending on how much
length/tension adjustment is available.
Hope this is useful to someone.
E.
PS: Mods: We used to be able to do neat tables using [
Bearings:
E.
Code:
] or [[pre]] (can't remember which). I tried doing this using the new forum interface and the result was almost illegible (and I couldn't bold or underline anything inside a preformatted block, nor change text colours). So if the above doesn't look very neat - that's why.
