WoodPecker
I've been looking into getting a chuck since Christmas, I thought a summary of what I've learned may be useful to other chuckless turners, I've been looking at this from the point of view of a CL3 owner, some of the chucks I've listed may not suite smaller lathes. The first six I mentioned are all 100mm scroll chucks (Though some don't state this I'm assuming that they are - scroll chucks that is) with one hand tightening capability. The Last 4 are listed for posterity. I'd appreciate further comments about any of the listings or comments about other chucks worthy of mention and of course if there may be some errors. I haven't commented on the vicmarc range as it doesn't appear to be readily available over here (But I stand to be corrected), there are some others I haven't mentioned due to lack of versatility. I've listed the first 6 by price:
Rutlands XT700 Precision Scroll Chuck
http://www.rutlands.co.uk/cgi-bin/psProdDet.cgi/XT700
Cost New:£99
Cost S/H:
Comes with: standard jaws offering an expansion grip of 70mm and a compression grip of 55mm
Advantages: Price. One hand tightening. Compatible with supernova jaws. Indexing ring.
Disadvantages: Backplate available only for 3/4" x 16tpi and 1" x 8tpi (However adaptors can be bought for about £10)
Philb wrote:
The Toolposts VersaChuck
http://www.toolpost.co.uk/pages/Chucks_ ... chuck.html
Cost New:£130
Cost S/H:
Comes with: dovetail jaws. Three sets of Mounting Jaws so that accessory jaws from Axminster, Teknatool (Nova, supernova) and OneWay Manufacturing (OneWay and Talon chucks only but not stronghold) can be mounted. Backplate (Less common ones are £10 to £20 extra).
Advantages: Can use jaws from 3 major manufacturers. One hand tightening. Backplate available for virtually any lathe. Indexing. Good Price
Disadvantages:
Comments: There was a glowing recommendation from one fourm user.
Supernova2
http://www.toolpost.co.uk/pages/Chucks_ ... rnova.html
Cost New: £140
Cost S/H: -
Comes with: 50 mm standard dovetail jaws and 8 mm Woodworm screw chuck
Advantages: Good range of jaws available. One hand tightening. Backplate available for virtually any lathe. Indexing.
Disadvantages: Geoff Tulip wrote:
Axminster Super Precision Chuck Option A/B
http://www.axminster.co.uk/recno/10/pro ... -29973.htm
http://www.axminster.co.uk/recno/11/pro ... -29974.htm
Cost New: £175 (Also on Axminsters site as a package deal for £150 comes with a set of dovetail jaws, but not in stock http://www.axminster.co.uk/recno/5/prod ... 363274.htm)
Cost S/H: £90 (visible rust) £115 4 Mths old excellent con with set of jaws. Both on ebay UK feb 2006.
Comes with: Not much really, either accessory mounting jaws or internal and external stepped jaws
Advantages: One hand tightening. Loads of jaws available. Indexing
Disadvantages: You’ll have to spend another £24 to get basic dovetail jaws.
SVB wrote:
Comments: The mutts nuts according to users, I haven’t come across any negative comments. The option A and B price seems a bit much but the package deal price is very good if it comes back into stock.
Oneway
http://www.craft-supplies.co.uk/cgi-bin ... |user||17|
Cost New:£130 + £20 for most thread adaptors
Cost S/H:
Comes with:
Disadvantages:
Comments:
Record Power RP4000
http://www.recordpower.co.uk/index.pl?p=RP4000&a=i
Cost New:£160
Cost S/H: around £110 on ebay
Comes with: indexing plate, woodscrew, standard jawset - expanding from 45mm to 85mm.
Disadvantages: According to RP4000 owners it’s awkward to change jaws, (would welcome more comments on this).
SVB wrote:
Also Ran:
Axminster Clubman Chuck K8
Cost New: £100
Cost S/H: -
Comes with: Mini C dovetail jaws
Advantages: Good range of jaws available. But no real advantages over other similarly priced chucks.
Disadvantages: Uses a tooted chuck key (Like a large conventional drill chuck key) which I would imagine is hard to open.
Comments:
Axminster Clubman Chuck K10
Cost New: £110
Cost S/H: -
Comes with: C type dovetail jaws
Disadvantages: ?
Comments: There are better chucks available for less money.
Record Power RP3000.. collet chuck
Cost New: £70
Cost S/H: I’ve seen them go on ebay for £35
Comes with: Range of contracting & expanding solutions, a faceplate, screw chuck and pin chuck are all included.
Advantages: Cheap.
Disadvantages: Only available with 3/4” x 16tpi mounting thread. Two hand tightening.
Comments: Two hand tightening means no spare hand for holding the wood.
Record Power RP3500..
Cost New:£110
Cost S/H:
Comes with: woodscrew and standard jawset
Disadvantages: Not sure how this tightens.
Comments: There are better chucks available for less.
Cost New:£99
Cost S/H:
Philb wrote:
Comments: Looks like a Good chuck at a great price. See user reviews on Rutlands site. But also note Philb's comment above.I bought one of the Rutlands chucks. It ran out of true by about 0.5 mm.
Naturally I sent it back and asked for a replacement which duly arrived last Friday. Guess what? it ran out by the same amount as the first one. It will be going back tomorrow and I will be asking for a refund
Cost New:£130
Cost S/H:
Disadvantages:
Supernova2
Cost New: £140
Cost S/H: -
Comments: Gets a lot of praise from users.the nova dovetail is not very deep and has a small step in the jaw which means that a recess that is too deep will tend to run out on the shoulder - which is a pain making pieces hard to mount
SVB wrote:
1) COST! It is the most expensive and if you decide to get a set of jaw carriers for each set of additional jaws you buy then the cost will add up.
2) Size - it is a large & heavy chuck. OK if you have a reasonable size lathe but it may be a bit big for the small lather (I have an Axminster M900 and it is about as small a lathe as I would use one on - weight / distance away from headstock vs machine bearings considerations etc).
3) I said in (2) above the build quality is excellent (which it is). However, I too bought my SP chuck on the deal you are looking at when it was first launched approx 18 mths ago. I had to return the first chuck as the action was very stiff. Apparently there are two sources of these chucks both made for axminster to (I am told) the same standards and tolerances. The ones sold as individual items for full price in the cataloge are Romanian, the ones sold as the kit are Chinese. However, when I took my first chick back for exchange I was told that all the future chucks, both sold as part of the kit and individually would be the Chinese one I was exchanging. Was my first chuck a rogue bad one? I am not sure, all I know is that the one I exchanged it for is A1, there was no bother in getting the exchange and I am v.happy.
4) I had to do a little draw-filing before I used it to remove the rough edges. 10 mins work but should it not be already done on the top of the range item
5) It is not coated / plated. This leaves it open to surface corrosion where as the record chuck IS plated and will always be shiny.
So, with £149 to spend on one one chuck which would I buy, I think I would have the APTC SP unit.
Oneway
Cost S/H:
Comes with:
Disadvantages:
Comments:
Record Power RP4000
Cost New:£160
SVB wrote:
Comments: There are more user friendly chucks available for similar price or less even.if you change jaws often it is a real pain to keep unbolting the little allen screws (this problem is worse still if you make you own jaws and have to align then each time - bowl reversing cole jaws for example)
Also Ran:
Cost New: £100
Cost S/H: -
Comments:
Cost New: £110
Cost S/H: -
Disadvantages: ?
Cost New: £70
Advantages: Cheap.
Cost New:£110
Cost S/H:
