chuck sticking on headstock spindle face
I have just experienced a jammed chuck in my Poolewood lathe. It won’t come free no matter what I do. Have started with wd40, banging a punch in the chucks holes and a square chunky piece of square metal in the chuck and a pair of stilsons but no joy.
Anymore advice.......Please?
In my experience it is a sudden rotational impact that you need to create, leaning on it gradually with leverage is no good. Do you have a secure method for locking the spindle? then square piece of wood/metal inbetween the chuck jaws sticking out as an arm, hit it with a mallet. Little bit of heat on the back of the chuck mounting plate to expand it may help. I am sure others will have advice as well.
I have been thinking about applying heat. I’ve got an experienced woodturner coming over to help me tomorrow......fingers crossed!
Lock the spindle.
Clamp a bar in the chuck (as pictured below).
Give it a clump with a big hammer.
You're ''less likely'' to damage the chuck this way.
Eureka!
An experienced woodturner came to help me today and even he had real issue s releasing it. By engaging the lock8ng pin and using brut fo4ce it was no surprise the locking pin snapped.
We opened the lathe up and used a strong bar to lock the spindle and eventually the chuck came free.
What a pain, but I’m using leather washers from now on!
Thanks for your advice.
Just a thought, some chucks/faceplates have an optional dual cut LH/RH thread (Graduate lathe to mention one). This means that the thread contact area can be quite low (probably only 30-40% at a guess, or even less!). This can apply considerable pressure on the thread flanks and cause binding. This happened to me recently on my Graduate. I have never used washers (yet) but would not use milk bottles as the plastic is blow moulded and thickness can vary considerably (so the washer can be tapered).
Tudor
Arnold9801":1y8gs4xz said:
Eureka!
:lol:
Tudor
I've always cut mine from the centre panels of six pint cartons, so the there is very little variation in the thickness. It might be measurable on a metal lathe but I very much doubt it's anything like enough to matter on a wood lathe.
I have only used a washer made from the shiny paper backing from the sheet of white sticky labels.
After I have used the sticky labels I keep the sheet handy in the shed.
It is a simple matter cutting out a 3/4" bore hole to fit over the nose, the outside diameter can be what you want but I use 1 1/4".
I reckon I have used 3 of these in 12 years and never had a chuck stick yet.
Cheap and reliable.
Don W
Dammit, I was hoping to use the 'wobbly washer method' to straighten out some of my dodgy bowls. :-D
