• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Wanted Chuck backplate for Axminster / Toolmex chuck.
tbsb33
17 Aug 2017
Romsey
I am looking for a chuck backplate to fit my Axminster supplied Toolmex 100mm chuck. The thread needs to be: 1.5" x 8tpi. This is to fit a Viceroy lathe. I have been told the backplate is an iso std 4" Pratt + Bernard design. It has a 3 bolt fitting.
Axminster used to supply the backplate with part no. 900072 but no longer available.
Just wondered if someone had one sitting in the corner looking for a new home ??
I think 1 1/2" - 8 is the same as a Boxford lathe.
You could try this from ArcEuro
https://www.arceurotrade.co.uk/Cata...ates/Backplate-BOXATL-VICSOU-5-112x8TPI-Plain
This might be a possiblity:
http://www.theengineersemporium.com/catalogue-pages/lathespares.html
You would have to turn the register yourself and work out how to fix the chuck to the backplate (I do not know if the chuck you have is front-mounted with counterbored holes in the chuck requiring threaded holes in the backplate or rear-mounted, requiring plain holes in the backplate).
Hi Phil and Chailatte
Thanks for the info. I will look at both suggestions.
My chuck is a Toolmex supplied by Axi. The plate is rear mount and it has a register for the spindle and one for the chuck body on the front. And 3 clearance countered holes for cap screws. Quite a lot of machining to do from a blank. Beaufort looks a possibility. I would prefer an Axi one but will explore all avenues.
Thanks again.
